Order Ford 9N Parts Online
9N Transmission ???
TheOldHokie
03-15-2008 16:25:59
I split my 9N this morning to do a little exploratory surgery on the final drive. When I removed the PTO shifter I managed to let the front of the countershaft slip backwards and out of the front bearing cup - arrgh! I haven't been able to coax it back into place working from the rear. If I remove the top cover on the transmission will I have sufficient room to get past the mainshaft and line it up from above? I don't relish the thought of having to tear it all the way down.
TIA,
TOH
Sean (TX)
03-15-2008 19:14:28
 Re: 9N Transmission ??? in reply to ok bill, 03-15-2008 16:25:59
Hobo is right about the bolt...you can see it in this pic...
third party image
Sean (TX)
03-15-2008 19:11:16
 Re: 9N Transmission ??? in reply to Sean (TX), 03-15-2008 16:25:59
Here is a shot with the main shaft removed. It would be hard to get at it with the main shaft and shiift rails in the way. John's idea seems they way to go...
third party image
main shaft is in this pic. its even tighter with the shift rails in there..
third party image
Hobo,NC
03-15-2008 18:08:58
 Re: 9N Transmission ??? in reply to TheOldHokie, 03-15-2008 16:25:59
Thought only, don't the end of the counter shaft have a bolt in it, if so remove it and make a threaded rod to use to help get leaverage to push it back in place
THEoLDhOKIE
03-15-2008 17:38:54
Thanks guys,
I'll give John's idea of poking from below a try. I'll jave to see if I can rent a second set of hands.
TOH
Dan
03-15-2008 17:20:01
third party image
The short answer is yes, but as John said - you should be able to rig something through the filler hole to lift up on it. This pic is kinda small, but there are a few good straight down views in my photo album.
Dan
John Smith8N
03-15-2008 17:13:24
third party image
Not much to the countershaft that could keep you from slipping it back into place. How about removing the drain plug and using a stick to lift up on the front end of the countershaft, then push forward from the back?
