Hex nut to the right of water pump
Randy Fountain
03-17-2008 10:09:25
"Bruce (VA)" mentioned in previous posts to remove the bolt to the right of the water-pump and squirt oil in to pre-lube the valve-train. I'm not finding the bolt. The only obvious bolts in the area are the head-bolts as far as I can tell. Does the bolt exist on the pre-1950 8n's?
On another note - I considered replying to his post in my previous thread but since that thread is three pages-in at this point I didn't know if it would be noticed. What is SOP for this type of situation? Make a new post(like this one) or reply to the older post?
Sean (TX)
03-17-2008 12:01:49
 Re: Hex nut to the right of water pump in reply to GA Dave, 03-17-2008 10:09:25
If you are in modern view a old post gets bumped to the top.
Modern View
JMOR
03-17-2008 10:50:05
 Re: Hex nut to the right of water pump in reply to Sean (TX), 03-17-2008 10:09:25
Randy Fountain said: (quoted from post at 13:09:25 03/17/08) "Bruce (VA)" mentioned in previous posts to remove the bolt to the right of the water-pump and squirt oil in to pre-lube the valve-train. I'm not finding the bolt. The only obvious bolts in the area are the head-bolts as far as I can tell. Does the bolt exist on the pre-1950 8n's?
Immediately above the most inboard distributor mounting bolt in photo attached.third party image
Dell (WA)
03-17-2008 11:54:12
 Re: Hex nut to the right of water pump in reply to JMOR, 03-17-2008 10:50:05
Randy..... ...the BIG (15/16") oilpump priming NUT in this picture is painted red so ya really gotta squint. Its above one of the two frontmount distributor bolts and is hidden behind the waterpump fanblade pulley extention in other picture. Watchout for the pressure spring going "sprong".
USE HEAVY OIL to prime oilpump, 90w or 140wt oil. You doubt? When you rebuild yer engine, you stuff yer oilpump gears fulla vasoline or chassis grease. Iff'n you use engine oil, it'll leak right past the oilpump gears before you even gitt the BIG NUT screwed back in. Yes, it is supposed to have a "flat".
And YES, start a NEW thread when yer original query pages to the NEXT page. Us responders don't really go checking to page#3 for new follow-ups, but YOU should always check back to yer original query just incase..... ...HTH, Dell
JMOR
03-17-2008 12:43:32
 Re: Hex nut to the right of water pump in reply to Dell (WA), 03-17-2008 11:54:12
third party image
Squint reliever:
Randy Fountain
03-17-2008 13:21:26
 Re: Hex nut to the right of water pump in reply to JMOR, 03-17-2008 12:43:32
That clears up both issues...Thanks again!
Dan
03-17-2008 10:26:03
 Re: Hex nut to the right of water pump in reply to Randy Fountain, 03-17-2008 10:09:25
The large flat oil relief valve cover bolt is to the left of the water pump if you are looking at the front of the engine. It is fairly flat and almost flush with the front timing cover, and at the top of that cover on the face. It is usually covered with oil, grease, and dirt so some scraping might be needed to locate it. This bolt is there on ALL 9N/2N/8N tractors.
HTH,
Dan
