Hydraulic Fluid Leak
jln
03-18-2008 17:34:27
Two things please:
- We have a 1952 8N with apparently a factory installed hyraulic system mounted on it. I recently replaced the distributor and the individual at the parts store saw the picture of it and said the hydraulics were in fact facotry installed and therefore the tractor is a collectors item..... ?? I don"t know how to upload an image here or I would.....we bought the tractor do some work and afer changing out the distributor, it performs beautifully... which brings me to the second thing;
- I have a serious hydraulic fluid leak coming from the box to the right of the drivers seat that has the lever to raise or lower the frontend loader. The leak seems to be coming from the shaft going into the box suggesting there is an "O" ring in need of replacement inside the box. Zero knowledge with hydraulics....can anyone out there steer me in the right direction?
Thanks in advance for the help!
jn
jln
03-20-2008 05:58:52
 Re: Hydraulic Fluid Leak in reply to jln, 03-18-2008 17:34:27
I appreciate putting the pictures up for me.
Does anyone have any ideas on what we have as a tractor - is it something that should be set aside and perserved as a collectors item instead of working it to death the way we are.....
Any thoughts on the leak hydraulic fluid problem and the best way to fix it?
This old girl is a hard worker. Everything basically works beautifully and I don't want to risk of damaging her unnecessarily.
I would appeciate any thoughts and help you might offer. Thanks
jln
Sean (TX)
03-19-2008 16:22:34
 Here are the pics in reply to Dunk, 03-18-2008 17:34:27
Long day at work...
third party image
third party image
soundguy
03-19-2008 05:36:28
I'd sure like to see that when it is posted..
soundguy
TheOldHokie
03-19-2008 08:12:58
 Re: Hydraulic Fluid Leak in reply to soundguy, 03-19-2008 05:36:28
Sounds like a remote valve tap added through the top cover.
TOH
Sean (TX)
03-18-2008 17:40:35
 Re: Hydraulic Fluid Leak in reply to Ultradog MN, 03-18-2008 17:34:27
Email me photo and I will post it..
mcdonoug@gvtc.com
