601 radius rod cap
Andy Mn
03-21-2008 18:24:18
I noticed today that one of my radius rod caps is cracked . I looked in the YT catalog and didn't see anything. I'm thinking mine is aluminum (looks like). My 8N looks about the same except the 8N looks like cast iron . Will they interchange ? Oh and I'm wondering ow th ell did that happen!
Dean
03-22-2008 04:36:58
 Re: 601 radius rod cap in reply to Andy Mn, 03-21-2008 18:24:18
Andy:
Chinese made reproduction radius rod sockets and/or caps are readily available. They are inexpensive so you might want to to swap both sockets and caps on both sides to tighten things up a bit.
Dean
Hobo,NC
03-22-2008 04:28:42
I would B on the horn to Jim.UT and replace'em
Sean (TX)
03-22-2008 04:00:27
 Re: 601 radius rod cap in reply to Dunk, 03-21-2008 18:24:18
From Dennis Carpenter website
8N-3440-B
(AA)
Radius Rod Cap
8,NAA
600-800
48-57
8.50 ea.
Jim.UT
03-21-2008 22:35:12
I may have one. I'll have to look. I think an 8N cap will work. They look the same to me.
Dell (WA)
03-21-2008 18:31:30
Andy..... ..generally, repair of cracked radius rod caps is by WELD. In situ or removed and done at welding shop. Loose sockets are usually "shimmed" by soft copper washer. (hole is beneficial to fit around ball) TIP: use magnet to check for aluminum or iron..... ...Dell
Andy Mn
03-21-2008 19:17:31
 Re: 601 radius rod cap in reply to Dell (WA), 03-21-2008 18:31:30
Dell , I was so sure it was aluminum , but I did check and it turns out to be steel ! But is it really worth welding ? Crack goes across one of the bolt holes . Think I'd rather get another one if I can . Think theres already a penny in there and that's what cracked it ? Or do they crack from shifting back and forth when they're worn ?
Ultradog MN
03-21-2008 21:22:43
 Re: 601 radius rod cap in reply to Andy Mn, 03-21-2008 19:17:31
Andy,
Dunno why it cracked. I would replace it myself.
Shouldn't be expensive. A few bucks and shipping.
I'd put an ad here in the classifieds for one.
An old timer told me the way to adjust for looseness around the ball is to put the flat side of the cap up to a grinder and remove a little of the metal. Grind and test to get a good - not too tight fit.
Where in MN are you. I'm in the Cities. Columbia Heights
Andy Mn
03-22-2008 05:43:07
 Re: 601 radius rod cap in reply to Ultradog MN, 03-21-2008 21:22:43
I went out and looked at the other side and It's just starting to crack!! So now I need two of them . I'm thinkin' maybee It's caused from having a loader on . And ya know just last month I had chained it to the trailer and hauled her home. Sure glad they didn't pull out then !! I went way up to Alexandria to pick this one up. I'm located down by Albert Lea . Ground is bare down here, we didn't get ANY snow...nada... zipo
Ultradog MN
03-22-2008 06:03:04
 Re: 601 radius rod cap in reply to Andy Mn, 03-22-2008 05:43:07
We've gotten at least 3" maybe even 4" and at 8:oo am it's still coming down though lightly.
Good luck with your caps.
