GB in MT.
03-22-2008 08:53:00
Re: 44 2N....Axle pin....finished pix...Last revisit in reply to Dan in CO, 03-22-2008 08:36:11
Dan in CO said: (quoted from post at 08:36:11 03/22/08) Gary;
As always, you do some fine work. That whole job must have been trying on your patience having Hermie apart with the snow flying. It has to feel good knowing that he is back together, better than ever and safe.
I have the Beast apart now, waiting for the radiator to be done. It is a good time for me to closely examine my front axel pin. What should I be looking for? There doesn’t seem to be any sloppiness in it, should I take the axel extensions apart to get a better look? I sent some pictures to you earlier; did you see anything I should be concerned about? |
Morning Dan;
Unfortunatly, the only way you will know for sure, what is behind the face plate of yer axle pin, is to dismantle it. :shock: I thought mine was OK, did not feel any slop in the front end, and had good responce to the steering, BUT.....you can see by the posts, about mine, that I was totally WRONG!!!!!
I could not see anything in yer pic's, that could tellya that you may/may not, have a prob., But...if you have the beast tore down for other fixes, I would say do it NOW, while you have it apart!!! Don't wait and have to tear it down, all over again. Makes for long hrs. and headaches!!!!! :lol: Let me know how/what ya find!!!! Make sure to replace anything that even remotely looks bad!!!!!
I have a parts manual, if ya need me to look up anything, just holler!!!!
HTH Gary :)
