engine swap pictures,and a couple questions,
Ratface
03-23-2008 14:51:40
engine next to hood is being swapped with other.
third party image
ready to start switching parts. drinking pepsi
third party image
Splines ready to be lined up with bolt guides.Need a beer.
third party image
Beer did the trick.
third party image
These are solid drag links, and I would like to change them to the newer threaded kind. I can not get the nut to tighten, it spins and spins.
third party image
Question: Upon trying to start I broke the starter clutch pin with a loud thud. I also broke a tang off the distributor. I had spares of both and finally got it started after playing with the distributor. Problem was no oil pressure was showing for a very long 10 seconds when it first started. It finally shot up to 20 psi. I was getting 105 compression on all cylinders prior to starting, wet, since I was trying to lubricate the pistons with some oil. The engine runs very smooth now but I hear like a twanging noise.It seems to be amplified from the exhaust. I don't know the history of the engine. Did I do some major damage while that oil pressure was absent? I also primed the pump through the priming hole with at least a cup of oil before starting.
woodie
03-24-2008 14:04:59
 Re: engine swap pictures,and a couple questions, in reply to Ratface, 03-23-2008 14:51:40
I like your ROPS, where did you get them
OH Boy
03-23-2008 15:50:42
Dunno about the 'twanging' noise (sticky valve maybe???) but I bet the ten seconds of no oil pressure was just the filter canister getting filled up. I think you had oil pressure to the bearings. I'm think it'll be fine.
ratface
03-25-2008 04:54:53
 Re: engine swap pictures,and a couple questions, in reply to OH Boy, 03-23-2008 15:50:42
The ROPS is from SAF-T-CAB, and I thibnk they are in California. I got it 8 years ago and even then it was close to 500.00. I think they go around 800.00 now. There are cheaper ones out there.
I think Oh BOY hit the oil pressure on the head. I drained the oil canister and changed the filter but forgot to fill it back up before starting.
