ford
al crow
03-25-2008 12:23:30
i just saved 2 ford farm tractor from a junk yard now i need help what do i have #lyc13 below that NAA4024 C i can get that one running the outher one is NDA 4024E can not get out of gear gear shift is off ceneter to the drive side it will go up and down ( i think that is high and low range) but can not get any gear at all also will not start i think ford has a safte swith in tran thank for any help u can give me
Joe in NYC
03-25-2008 19:13:10
 Re: ford in reply to al crow, 03-25-2008 12:23:30
If it is a 5 speed like mine(851) try wiggling your shifter lever in various positions(up, down, left, right) while trying to start it. With age the safety switch goes out of alignment with the shifter and it becomes difficult to activate the switch(in neutral only). Others have mentioned having the same problem. If it's not too far gone you may still be able to start it this way. Joe in NYC
BillM (OH)
03-25-2008 13:19:38
Sounds like the NDA tractor is an 800 series with 5 speeds forward, 1 reverse. Center position (vs forward & back) is neutral and gear choices are stacked 2/2/2 up and down, if you can get it to the neutral position. It does have an interlock, so if you can"t get it in neutral, big starter switch on the tranny won"t work.
Brian Bell
03-25-2008 13:11:47
The NAA4024 is a 1953 Model NAA "Golden Jubilee" tractor. The NDA should denote an 800 tractor. The SN for it is located on the flat spot just behind the starter. See the link for more details.
