Order Ford 8N Parts Online
8n-10145 throttle rod spring
AdamP
03-25-2008 13:03:28
Ive looked in the search part but have not found the dimensions of the 8n-10145. I was wondering if some one could scan it to a PDF and post it. Also I am looking for a picture of how the spring mounts on the throttle handle rod. Thanks to oldhoki for the front axle pin, works great. AdamP
JMOR
03-25-2008 19:05:32
 Re: 8n-10145 throttle rod spring in reply to don b, 03-25-2008 13:03:28
AdamP said: (quoted from post at 22:01:47 03/25/08) Thanks for the picture. Its the spring labeled 9806
just can not see how it is installed. Thanks for all the help. AdamP
Adam, there are plenty of folk here that can answer the "how", I just not one of them, but they will show up..... hang in there.
JMOR
03-25-2008 18:20:03
 Re: 8n-10145 throttle rod spring in reply to Andy MN, 03-25-2008 13:03:28
AdamP said: (quoted from post at 16:03:28 03/25/08) Ive looked in the search part but have not found the dimensions of the 8n-10145. I was wondering if some one could scan it to a PDF and post it. Also I am looking for a picture of how the spring mounts on the throttle handle rod. Thanks to oldhoki for the front axle pin, works great. AdamP
Probably one of these two.third party image
AdamP
03-25-2008 19:01:47
 Re: 8n-10145 throttle rod spring in reply to JMOR, 03-25-2008 18:20:03
Thanks for the picture. Its the spring labeled 9806 just can not see how it is installed. Thanks for all the help. AdamP
AdamP
03-25-2008 13:57:44
 Re: 8n-10145 throttle rod spring in reply to AdamP, 03-25-2008 13:03:28
I should have stated that my tractor is a 40-41ish 9n. No number on the block. She has the cast steel front axle housing and old pin. grease zerks on back side similar clutch and brake lever and interlock starting button all of which I'm working on. Im not going back to exact original but making a mechanically sound tractor that is close. Thanks, AdamP
don b
03-25-2008 17:51:13
 Re: 8n-10145 throttle rod spring in reply to AdamP, 03-25-2008 13:57:44
Adam...I think you are looking for part number 9n9827.This attaches to the throttle rod and then to the governor.It is called the governor compensating spring.Don't have a clue as to where you came up with that part number. don b
8N'r--WI
03-25-2008 13:26:11
Adam--if you are asking about the throttle control rod spring--this may help--if not, disregard.
third party image
The spring for the 8N is part #8N9806 and is 2.75" long with an I.D. of .42"
The spring for the 9N and 2N is shorter but has a wider I.D.
Tim
