Order Ford 9N Parts Online
9N TRANS REMOVAL
randy123456789
03-25-2008 18:55:15
after removing nuts and bolts between transmission and rear end on 9n tractor, does the transmission just slide off? i hope it has a set of splines
Jim.UT
03-27-2008 09:36:30
 Re: 9N TRANS REMOVAL in reply to randy123456789, 03-25-2008 18:55:15
In order to take a 9N trans apart, you will need to disconnect it from the engine, too. You need to be able to access both ends to remove end caps, etc. Pulling the gear assemblies out the top of a 9N trans is tricky. Things are packed in there pretty tight. It's not rocket science, but you gotta hold your mouth just right.
I have a complete 9N tranny (less top cover and shifter) out back. I've been meaning to dismantle it and part it out, just haven't yet.
Sean (TX)
03-26-2008 02:36:33
 Re: 9N TRANS REMOVAL in reply to Hobo,NC, 03-25-2008 18:55:15
I got my bearing and seal kit from this site. If you need good used gears or shafts check with john smith..
third party image
Sean (TX)
03-25-2008 19:19:34
 Re: 9N TRANS REMOVAL in reply to Billy Goat, 03-25-2008 18:55:15
I used a floor jack and supported the center housing and rolled the rear half back. They will just roll apart when unbolted...With the rear wheels chocked you can pick the center housing up and point it strait up and drain the rest of the oil out where the PTO shaft goes in.. 8) Not as heavy as it looks you dont want to drop it thou!!!
randy123456
03-25-2008 19:38:08
 Re: 9N TRANS REMOVAL in reply to Sean (TX), 03-25-2008 19:19:34
thank you Sean, i am taking apart trans, bad noise in first gear
