Update on Elecronic Ignitions?
Ron from IL
06-07-1999 10:28:38
Hi Guys!
Is there any update on electronic ignitions for front-mounted distributors (9s,2s and early 8s)? Several months ago, someone talked like this was in the development stage, but still not available to the general public. Anyone have any news? Ron
Jim
06-08-1999 05:06:15
 Re: Update on Elecronic Ignitions? in reply to Ron from IL, 06-07-1999 10:28:38
Ron, These are available from several sources now. There is an outfit (Performance Automotive) in Colorado that advertises (Petronics Ignition Systems) in Hemmings that is the most reasonable. Their unit is a 12 volt. Another vendor in CA, Redmound Ingitions has another version that can be bought in 6 or 12V. His are a lot more expensive.
JK MN
06-08-1999 06:50:10
 Re: Re: Update on Elecronic Ignitions? in reply to Jim, 06-08-1999 05:06:15
Jim, Most of the electronic ign's are for (12V, negative ground,) "regular" side mount type distributors. If you know about a set-up for the front mount 9N, 2N, & 8N front mount distributors, let us all know the part number. Internal distributor workings has no room to put a typical magnetic rotor ring on the front mount distributor. We all await your reply.
