Wheel Color
nondem
03-28-2008 05:05:13
I've found a wealth of information about the red and grey but not much on wheel color.
Did a 19508n have grey rear wheel rims or white? two-color?
What about the fronts?
Dunk
03-28-2008 07:17:59
 Re: Wheel Color in reply to nondem, 03-28-2008 05:05:13
Here is a Google search of this site for Cadmium
Link
There may even be different colors of Cadmium???
Here is a search of Eastwood Paint for Cadmium, and they show both a gold, and a silver.
Link
Dunk
03-28-2008 06:50:27
 Re: Wheel Color in reply to OK, ZANE..John,PA, 03-28-2008 05:05:13
Bruce (VA) said: (quoted from post at 10:46:55 03/28/08) I thought the rear rims were cadmium also, but my color chart says zinc. Lug bolts & nuts, oil filter canister bolt & timing gear cover bolts were also zinc plated. Gas tank, wire tube, throttle rod & plate were cadmium plated. At least, that's what the color chart says.
For sure Bruce, I don't know.
Just what I have heard, or read somewhere.
Dunk
03-28-2008 06:16:10
 Re: Wheel Color in reply to Wyo, 03-28-2008 05:05:13
Bruce (VA) said: (quoted from post at 09:14:23 03/28/08) The entire front wheel & rim where the same color as the 'grey' on the tractor. The rear wheel was also this color, but the rim was zinc plated (sorta silver colored).
50 Tips
I beg to differ, Zinc is used for galvanize, and yes it is a silver color.
Link
I think the rear wheels came Cadmium, which is an impurity in Zinc, which is kinda of a yellowish silver color.
Link
I could be wrong though.
Bruce (VA)
03-28-2008 06:46:55
 Re: Wheel Color in reply to Dunk, 03-28-2008 06:16:10
Dunk
03-28-2008 07:21:46
 Re: Wheel Color in reply to Bruce (VA), 03-28-2008 06:46:55
TIMW(PA)
03-01-2005 07:31:02
68.162.176.246
485286
Re: 8n rear wheel color? in reply to Dave Beck, 03-01-2005 07:03:03
The original rims were Silver Cadmium plated. Since a real Cadmium plating job would probably be astronomically expensive most restoration jobs will use a silver colored paint to give it the right "color". SouNdguy found a Cad paint in rattle cans when he was doing his restoration on his Allice G awhile back that looked pretty authentic...Tim
Link
Bruce (VA)
03-28-2008 05:14:23
