O/T GL4 or GL5
9N again
03-28-2008 13:39:49
Howdy Y'all
You all seem to know somthing about everything so I will ask. I have a troy built roto tiller and they say for the gear oil to only use GL4 140 or 85w-140, i cant find GL4 anywhere but i can find GL5. Will this work. Any ideas.
Thanks
Bob
03-29-2008 05:55:36
 Re: O/T GL4 or GL5 in reply to 9N again, 03-28-2008 13:39:49
Tillers typically use a "worm gear" drive. Often, the wheel that it wears against is BRASS.
The severe-duty additive that makes GL-5 what it is is typically BAD for brass.
I WOULDN'T take the chance of using GL-5.
Dunk
03-28-2008 16:45:06
 Re: O/T GL4 or GL5 in reply to Pain..John,PA, 03-28-2008 13:39:49
GB in MT. said: (quoted from post at 20:01:24 03/28/08)
Yes Dunk, BUT..... .I always knew you were smarter than the average MONKEY>!!!!! !!!!!
third party image
Gary :lol:
third party image
When I got mine, I tool it all to pieces, it had a lot of wear on it.
The shaft bearings that the worm shaft rides in had a lot of play in them.
They were destroying the brass gear on the tines.
I grinded down a big washer to make a shim, and tightened them up, it still works fine, years later.
GB in MT.
03-28-2008 16:51:14
 Re: O/T GL4 or GL5 in reply to Dunk, 03-28-2008 16:45:06
When I got mine, I put gas in the tank!!!!! :shock:
LMAO
Gary :lol: :lol: :lol:
Dunk
03-28-2008 15:55:52
 Re: O/T GL4 or GL5 in reply to Denny(NY), 03-28-2008 13:39:49
GB in MT. said: (quoted from post at 19:42:40 03/28/08)
9N again said: (quoted from post at 13:39:49 03/28/08) Howdy Y'all
Thanks
9N again;
Go to NAPA, look on the shelf for NAPA part# 75-210!!! Gear oil, SAE 80w-85w-90.
On the back of the bottle it states..... API services...GL-5, GL-4, GL-3
This was recommend to me by my local Troy-built parts Dealer, and I have used this in my Troy-built "HORSE" tiller for yrs.
Comes in 1 quart bottles, easy to use, and even has a plastic pour-spout top on it.!!!
HTH
Gary :)
That's what I have in mine, Gary.
GB in MT.
03-28-2008 16:01:24
 Re: O/T GL4 or GL5 in reply to Dunk, 03-28-2008 15:55:52
third party image
Gary :lol:
GB in MT.
03-28-2008 15:42:40
Thanks
9N again;
HTH
Gary :)
TheOldHokie
03-28-2008 14:20:52
 You be the judge in reply to 9N again, 03-28-2008 13:39:49
Thanks
You be the judge:
API Gear Oil Service Designations (PDF)
To summarize those 12 pages the central difference between GL4 and GL5 service designation is that GL4 designation indicates a lubricant has anti-wear additives suitable for use with spiral bevel and hypoid gearsets operating under mild to moderate loads and speeds. GL5 designation indicates a lubricant with additional additives for use with spiral bevel and/or hypoid gearing operatiing under severe loads and at high speeds.
What's in your Troybilt ;-)
TOH
TheOldHokie
03-28-2008 14:27:52
 PS in reply to TheOldHokie, 03-28-2008 14:20:52
By the way that document is dated 1995 and notes that some test equipment needed to test for GL4 compliance is no longer available - perhaps why the designation is getting harder to find - manufacturer's are just skipping GL4 in favor of GL5.
