stripped head bolt threads
8N Nut
04-01-2008 10:26:22
Can anyone tell me of a repair for stripped threads (front center hole in block)? Thanks!
Dan
04-01-2008 11:34:28
 Re: stripped head bolt threads in reply to 8N Nut, 04-01-2008 10:26:22
I just had to do a few of these on my 1939 9N I had to drill 12 sheared of head stud on.
*Disclaimer* - you "should" use a milling machine or similar set up to ensure the drill goes in perfectly straight into the hole.
Get a Heli-coil set (or other thread insert) from your local harware store for a 7/16-14 size. Get the whole kit with the drill bit, tap, heli-coils and installation tool. I used a hand drill and checked for straightness on two sides, then drilled into the stripped hole using the supplied drill bit - is should go through like a hot knife through butter if you are lined up right, you are really only shaving the threads out. Now here is the REALLY important part - using the provided tap - tap new thread into the fresh hole you just drilled. MAKE SURE the tap is going in perfectly straight into the hole. You can tweak it a bit within the first few threads cut - but after that, forget it. If you are the slightest bit off - the studs/bolts will not line up right with the head and may require a little "modification" to the sides of the hole in the head to get them to fit... I used a framing square flush to the block and checked two sides 90 degrees apart MANY times during the process. Now that you have nice pretty threads cut into the block, put a little permanent thread locker on the inserts and screw them into place and WHOO-LAAA, a nice new head stud/bolt hole with new clean threads that are stronger than the originals.
Not too bad once you get the hang of it.
Dan
Eric in IL
04-01-2008 11:31:56
Click on the link for a look at an insert.
TheOldHokie
04-01-2008 10:29:13
Thread repair insert - drill it oversize, tap it, install insert, install original fastener. Available at fine industrial suplliers everywhere ;-)
TOH
