Order Ford 8N Parts Online
Ford 8N Clutch Adjustment
Paul Chamberlin
06-08-1999 10:09:24
My Ford 8N clutch ran out of adjustment and will not freely disengage. I split the tractor and replaced the 3 stud bolts(worn out) on the pressure plate along with the throw out bearing. The clutch plate, pedal shaft, and fork lever are in good condition. I am still not able to adjust the clutch to achieve complete disengagement. Any advice will be appreciated, especially if it proves to be what's needed to remedy the problem.
ZANE
06-08-1999 19:48:40
 Re: Ford 8N Clutch Adjustment in reply to Paul Chamberlin, 06-08-1999 10:09:24
It might be possible that the adjusting yoke is broken where the threaded bolt part is attached to the adjuster and is gaping open when the clutch pedal is depressed. I have seen this condition a number of times and it will make you crazy till you fine it Look close.
