Order Ford 8N Parts Online
Operation 8N: Left Axle Out
Ed S. (IL)
04-04-2008 20:16:58
In order to get better access to the left brake rod, I needed to pull the axle and brake assembly out of the trumpet. Should be as simple as removing six bolts and sliding the axle out, but I had one bolt that didn't want to budge.
third party image
It took about 2.5 hours of alternating heat, PB blaster and a 3lb. sledge on the cold chisel to finally get it to break loose.
third party image
I still like painting better (note the red oxide-coated transmission section).
es
Ed S. (IL)
04-05-2008 06:43:59
 Re: Operation 8N: Left Axle Out in reply to Ed S. (IL), 04-04-2008 20:16:58
Thanks for asking, Gary. Hand is doing pretty good, but by the end of the day, it can get to throbbing a bit, especially if it's been 'down' a lot. I have almost all my range of movement back, and probably 85-90% of my grip strength back. Still looks a mess, and will probably carry a nice scar the rest of my life.
es
GB in MT.
04-05-2008 06:54:09
 Re: Operation 8N: Left Axle Out in reply to Ed S. (IL), 04-05-2008 06:43:59
Ed S. (IL) said: (quoted from post at 06:43:59 04/05/08) Thanks for asking, Gary. Hand is doing pretty good, but by the end of the day, it can get to throbbing a bit, especially if it's been 'down' a lot. I have almost all my range of movement back, and probably 85-90% of my grip strength back. Still looks a mess, and will probably carry a nice scar the rest of my life.
es
Reminders are somtimes a very good thing!!!!! The pain of mistakes are too often forgotton, but the scars always remind ya of the past. :roll:
Glad it is doing better, NOW.... get out there and finish the job!!!!! :lol:
Have an "N" day.
Gary :)
GB in MT.
04-05-2008 05:30:36
Ed;
Looks like you are hard at it.!!! How is the HAND holding up under all that wrenchin',and strainin'???
Bet the musles are still healing.!!!!
Keep us posted, and good luck. Be careful!!!!
Gary :)
