Order Ford 8N Parts Online
8N drawbar mounting bolts
Phil_in_WA
04-05-2008 12:39:34
Does anyone have a pattern for these bolts handy?
Tractor is a long way (600mi) from me and the Bridgeport.
Thanks.
Dunk
04-05-2008 15:38:32
 Re: 8N drawbar mounting bolts in reply to Phil_in_WA, 04-05-2008 12:39:34
Phil, might want to drill them holes 1/8 inch (at least) oversize.
:shock:
Dunk
04-05-2008 15:36:23
Scholars, and Gentlemen, thank goodness, this place is full of 'em.
jon
04-05-2008 15:09:46
 Re: 8N drawbar mounting bolts in reply to Sean (TX), 04-05-2008 12:39:34
Dell (WA) said: (quoted from post at 18:03:56 04/05/08) Phil..... .fer you special..... I went out an'layed onna WET ground and calipered my under the diffy swinging drawbar mount. I gott 3-3/8" x 6" OC. Studbolts are 3/4NC innna diffy but 3/4NF NUTS. Don't use too LONG bolts 'cuz you'll bottom-out and CRACK yer diffy anna leek'em olly the place. Gazzuntite!!.....sniff, gonna gitt sniffer of brandy to ward-off them chillys..... ...Dell, hack-hack..... (little sympathy here?)
I first read this post & noticed it had been posted for an hour. Figured somebody had a tractor in the dry & would post it so waited another hour. No answer. Like Dell I trudged through the rain & mud to measure mine & now the questin has been answered. Terriffic!:roll:
For the record I got 6 x 3.5 or thereabouts. Dell's are probably more accurate though.
Dunk
04-05-2008 13:53:50
 Re: 8N drawbar mounting bolts in reply to Bob Harvey, 04-05-2008 12:39:34
Jim SC said: (quoted from post at 17:51:03 04/05/08) I think you are WRONG! Dell is normally a great mind reader...he must have a cold or a headache today.
Probably has the X Ole Lady on his mind....
:lol:
Dunk
04-05-2008 13:00:57
It sounds like he is wanting a pattern for the bolt holes on the bottom of the 8N rear end to me, but just a guess...
Phil_in_WA
04-05-2008 13:15:33
 Re: 8N drawbar mounting bolts in reply to Dunk, 04-05-2008 13:00:57
Sorry not to be specific. My bad.
Just looking for the spacing between the bolts where the drawbar would mount on an 8N
Also the bolt diameter.
Goal is to drill a piece of steel that will bolt on there.
Thanks
Dell (WA)
04-05-2008 12:51:25
third party image
Phil..... .uhh? this what yer askin'bout?? 3-point lower link pins. $20 (cheap)..... .Dell
Phil_in_WA
04-05-2008 13:20:01
 Re: 8N drawbar mounting bolts in reply to Dell (WA), 04-05-2008 12:51:25
Nope. Sorry not to be specific. I know you are not a mind reader.
Just looking for the spacing between (and diameter of) the 4 bolts under the rear end where the drawbar bolts on.
Goal is to drill a piece of steel to match.
Thanks
Dell (WA)
04-05-2008 15:03:56
 Re: 8N drawbar mounting bolts in reply to Phil_in_WA, 04-05-2008 13:20:01
Jim SC
04-05-2008 13:51:03
