Order Ford 8N Parts Online
Operation 8N: Left Trumpet Painted, Diff Case Cleaned
Ed S. (IL)
04-06-2008 11:06:46
Saturday was a delightful day here in the Middle West - temps in the mid-60s, sunny skies and relatively mild winds. I had a number of farm chores to do (some of which involved laoding and spreading accumulated manure from over winter), but did get to spend some quality time on the 8N.
I pulled the left trumpet off, wire brushed and painted that, and then removed the differential gear and hydraulic pump so I could clean out both sumps. As you can see from the photo, I got a good handful or more of mud out of the bottom...
I also tried to hammer out the toplink pin, but it's not having any of it. Used heat and the 3 lb. sledge on a drift, and no luck. I may just leave it as-is and clean and paint as best I can around it.
es
third party image
third party image
third party image
third party image
Ed S. (IL)
04-07-2008 04:17:22
 Re: Operation 8N: Left Trumpet Painted, Diff Case Cleaned in reply to Ed S. (IL), 04-06-2008 11:06:46
Ross,
That's red oxide primer - I have cans of Ford Red and Grey all ready to go once we getter bolted back together.
es
Sean (TX)
04-06-2008 14:43:50
 Re: Operation 8N: Left Trumpet Painted, Diff Case Cleaned in reply to TheOldHokie, 04-06-2008 11:06:46
looks good...Nothing like giving that belly a good cleaning while you are in there...
Ross Pugh(NC)
04-06-2008 14:23:20
You should have used Ford Red instead of Allis Orange! Looks good 'cept fer that orange paint, of course it is your tractor and not mine, so your choice of color is OK.
Jim SC
04-06-2008 13:37:34
Looks good. Keep the pics comin'.
