Sherman trans.
Andy Mn
04-06-2008 16:38:10
I'm looking at a 700 with a sherman trans.Does this trans. have a nutral position ? With the sherman lever forward you can spin the starter. Move it back and hit the starter again and the tractor moves.Could there be stripped gears in there ? They're going to auction this off in the morning, I'm interested , but don't know what i'm getting into. Tractor don't look too bad, Not all dolled up, just a workin' tractor that I could fix up and use.
soundguy
04-06-2008 18:10:52
 Re: Sherman trans. in reply to Andy Mn, 04-06-2008 16:38:10
If the starter spins witht he tractor in gear.. then I assume the interlock has been bypassed?
soundguy
Andy Mn
04-06-2008 19:36:17
 Re: Sherman trans. in reply to soundguy, 04-06-2008 18:10:52
Yeah, I think they did something to the interlock, cause it let the starter work in gear .
soundguy
04-07-2008 04:12:52
 Re: Sherman trans. in reply to Andy Mn, 04-06-2008 19:36:17
That would be one of the first things I'd fix!
soundguy
Den N Ms
04-06-2008 17:15:50
Andy,Yes it does have a neutral position,but it should have a lower gear with the lever forward all the way.Check the Smith page.
Andy Mn
04-06-2008 17:56:11
 Re: Sherman trans. in reply to Den N Ms, 04-06-2008 17:15:50
I looked at the Smith site .I see the "combo" trans has an "H" shift pattern . Maybe thats what this is, hope so. We'll see what happens in the morning , hopefully the owner will be there to tell about it
Den N Ms
04-06-2008 17:28:37
Andy ,It should have a Low Shift pattern N High
or a Direct -N Low High Shift pattern
