Order Ford 9N Parts Online
9N drag links or drag bar?
randy123456789
04-07-2008 16:10:14
my studs that come out below the diff. where the drag bars connect are leaking gear oil. is there a fix for this, i tried to tighten studs but they just spin. any ideas?
JMOR
04-07-2008 16:41:52
 Re: 9N drag links or drag bar? in reply to randy123456789, 04-07-2008 16:10:14
LIFT LINKS. The bolt turns because you are not holding the nut. Remove the axle trumpets to put a wrench on the nut.
