In frame rebuild?
nondem
04-07-2008 16:30:38
Can the oil-pan come off w/o "splitting" the tractor?
jon
04-07-2008 17:18:42
 Re: In frame rebuild? in reply to Dell (WA), 04-07-2008 16:30:38
nondem said: (quoted from post at 20:12:11 04/07/08) So if I put all 4 corners on jack-stands - as if I were gonna swap all the tires - that will properly support the rest of the tractor while I R/R the pan?
Not without the midsection being supported. Just put something in under the tranny & frontend for support, don't worry with the rears.
nondem
04-07-2008 17:12:11
 Re: In frame rebuild? in reply to old, 04-07-2008 16:30:38
JohnMD
04-08-2008 04:24:41
 Re: In frame rebuild? in reply to nondem, 04-07-2008 17:12:11
No you need a support under the transmission. The front of the pan bolts to the front axle. When you take those bolts out the front axle no longer provides any support. It is better to block the back wheels, front and back, use wood blocks to build a support under the transmission and then remove the front axle before pulling the pan. This will give you more room to work on the engine.
Rick8Nrookie
04-07-2008 16:59:50
 Re: In frame rebuild? in reply to GB in MT., 04-07-2008 16:30:38
Just make sure that you have the front of the tractor and mid section raised and supported. I know from first hand experience that the oil pan is part of the tractor frame and helps to support it. I tried to take mine off without any support and cracked my timing gear cover....still trying to get everything back together.
Ultradog MN
04-07-2008 16:35:40
 Re: In frame rebuild? in reply to nondem, 04-07-2008 16:30:38
Yes
