Freds new home
Sean (TX)
04-08-2008 16:11:32
Makes a nice weather shield for him and keeps the sun off me!!
third party image
This is the second 9N/2N I pulled apart that had leaking sure seals...Looks like they were pretty rough on them when the put them on. Going to put in new sure seals and clean the brakes...
Going to try and braze this backing plate has rust through!!! If that dont work I am in the market for a used one....
third party image
Desided to remove a upper lift arm...That took alot of heat and 100? Blows with a BFH!!!
third party image
third party image
Oil soaked brake drum. Brakes were working ok when I rolled it off the trailer. Must be cuz it has been sitting awhile and the brakes soaked up the oil..
third party image
Sean (TX)
04-09-2008 02:37:57
 Re: Freds new home in reply to Barry B, 04-08-2008 16:11:32
Its a motorcycle jack. I got it a harbor freight.
Sean (TX)
04-09-2008 02:35:27
 Re: Freds new home in reply to Hurk, 04-08-2008 16:11:32
HOA wont approve one of those... neighbor had his boat in one they told him to take it down. This didnt cost me anything...So if they see it all I have to do is take it down. Have my boat blocking the view of the shed now.
rodgernbama
04-08-2008 20:01:25
 Re: Freds new home in reply to Sean (TX), 04-08-2008 16:11:32
Sean: Is that an atv jack supporting the front? I got leaking seals on mine that I need to fix also.
Sean (TX)
04-08-2008 18:59:46
 Re: Freds new home in reply to Idaho Shooter, 04-08-2008 16:11:32
Not to mention a bushing for the clutch pedal..No sign of one of those :lol: Need a pin for the the front of the clutch rod. It was rusted to almost nothing. I need some pics of the rusty parts they are good for a laugh :lol:
Sean (TX)
04-08-2008 18:56:36
 Re: Freds new home in reply to Dunk, 04-08-2008 16:11:32
I guess those splines need a good wire brushing and some never seize...Did you use a torch to get yours off Joe? Not fun...so far everything has come apart pretty easy. I had to use the torch on 3 nuts on the rear axle. Nuts were rusted to almost nothing :lol: Axle was no problem to remove...Need to order some new shims to set the preload.
Sean (TX)
04-08-2008 17:50:16
I have all the photo's to..on my hard drive, photo bucket and myspace.. 1.3 GB on my hard drive LOL but that is not all tractor photos...I need to back those up on cd..or should I say cd's :lol:
GB in MT.
04-09-2008 01:27:17
 Re: Freds new home in reply to Sean (TX), 04-08-2008 17:50:16
Sean (TX) said: (quoted from post at 17:50:16 04/08/08)
Yeh. It's amazing how fast the hard drive gets used up, when you are saving pix.
Why didn't you go get one of the carport things, like Hermie's house.??
That way you would have had a place for both "N"'s!!!! The one I bought, was only $148.00, if I remember right!!! Under $200 I know.
10 X20 X10
Gary :)
Sean (TX)
04-08-2008 16:57:51
 Re: Freds new home in reply to Hobo,NC, 04-08-2008 16:11:32
One thing good about this tractor is the last guy used never seize...Upper lift arm bolts had never seize but no never seize on the splines on the upper lift arm. I can also see that both trumpets were removed in the past. Had orange glue and no gaskets from what I can see so far...
Joe T (CO)
04-08-2008 18:00:16
 Re: Freds new home in reply to Sean (TX), 04-08-2008 16:57:51
The guy I bought mine from never used never seize :-) The BFH was SOP :-)
I use it all the time :-)
Looking good, I like the shack too!
GB in MT.
04-08-2008 17:40:46
Sean;
LOL Not counting the folder on the 9N tranny, you have 8.08 meg. of pix in Fred's folder. That is start to date. :shock:
Keep it up!!!!! :lol:
Gary :)
Sean (TX)
04-08-2008 16:46:12
 Re: Freds new home in reply to Jim SC, 04-08-2008 16:11:32
Thanks...Ill let you know!! I may try brazing it wednesday..that upper lift arm wore me out LOL
HCooke
04-08-2008 16:37:35
If you can't fix your backing plate I have one you can have for the cost of shipping from St. Louis. Send email.
