radius rod bolt
Sean (TX)
04-09-2008 16:11:38
Is this the right bolt for 2N radius rod bolt? I was expecting a hex head...thats what I pulled off it?
third party image
third party image
Sean (TX)
04-10-2008 15:58:23
 Re: radius rod bolt in reply to Dick Calland, 04-09-2008 16:11:38
Looked into it a bit. I see the FO4 shows a pin and cotter pin. The are the same size as the old bolts. I guess they are keepers...
BQCat
04-10-2008 01:27:47
 Re: radius rod bolt in reply to Sean (TX), 04-09-2008 16:11:38
Sean, If I remember right it was a square head bolt on pappys ole original arms. A regular hex head bolt is prob the cheapest way ta go.
BQCat
JMOR
04-09-2008 22:06:50
 Re: radius rod bolt in reply to TheOldHokie, 04-09-2008 16:11:38
Sean (TX) said: (quoted from post at 19:11:38 04/09/08) Is this the right bolt for 2N radius rod bolt? I was expecting a hex head...thats what I pulled off it?
third party image
third party image
Both our 8Ns are 1950 & have the recessed smooth top bolts, which I believe started in 1948. Before that were hex. As far as I know, anyway.
Lumpy
04-09-2008 21:15:58
Nope! Thats what my dads 640 has and my old 861 had. Most of the 2n's and 8n's I have seen, have a hex head. My '47 2n has hex head.
DON TX
04-09-2008 16:39:08
It looks like my 841 rr bolt. My 9Ns have hex head bolt. My 841 measures 5". 8/9Ns measure 4 1/2". I need some for my 841 if you can't use em. HTH
DON TX
36 coupe
04-11-2008 14:45:10
 Re: radius rod bolt in reply to DON TX, 04-09-2008 16:39:08
Ford dealers supplied a hex head bolt 20 years ago.
