Ground Strap and Key ignition Locations
Ritt
06-09-1999 09:12:34
On a 48 8N where does the ground strap get hooked up? Was this tractor originally equiped with a key switch? Where is the proper location? Thank for the help with the details, trying to get this restoration right!
bg
06-09-1999 12:10:09
 Re: Re: Ground Strap and Key ignition Locations in reply to bg, 06-09-1999 12:07:17
The keyswitch is located under the left bottom corner of the dashboard. There should be a stamped metal mounting plate where it goes in.
Don B
06-09-1999 17:47:20
 Re: Re: Re: Ground Strap and Key ignition Locations in reply to bg, 06-09-1999 12:10:09
Just another comment to those who are trying to put their tractor back to original.The light swx. is attached to a small 2 inch long bracket that attaches to the 2 bolts on the voltage reg.plate under dash on the right side of the 47-mid 49 tractors.If anyone desires a pic or drawing of this brkt.,e-mail me.Don
