king kutter disc bearing options ?
award
04-10-2008 15:47:33
2 different discs and what are the differences in the bearings regarding wear and quality?
Box frame: The disc gang axles are made of 1" square high carbon steel rods mounted on double thrust sealed steel bearings.
Angle frame: The disc gang axles are made of 1" square steel rods mounted on double thrust ring gray-iron bearings
soundguy
04-10-2008 21:04:45
 Re: king kutter disc bearing options ? in reply to award, 04-10-2008 15:47:33
sealed bearings are great untill the seal goes.. then the bearing dies almost immediately.
the grey iron bearings.. you just grease the snot out of them till they are worn slap out..
soundguy
award
04-10-2008 22:11:37
 Re: king kutter disc bearing options ? in reply to soundguy, 04-10-2008 21:04:45
thanks soundguy. i appreciate the info. i am thinking of getting the angle disc and when on sale it goes for $570
in wisconsin you just cannot find a small disc for these ford tractors. been looking for a year now so i may as well buy a new one.
thanks again
8N'r--WI
04-11-2008 13:16:17
 7' Disc for Sale in reply to award, 04-10-2008 22:11:37
Award--did you see this one for sale on Craigslist? 4/8 in Baraboo. $575
third party image
What part of the state are you in? I know of a couple that I have passed on while waiting for the "right one".
Good Luck--Tim
award
04-11-2008 13:51:28
 Re: 7' Disc for Sale in reply to 8N'r--WI, 04-11-2008 13:16:17
shawano, wi.
about 1/2 hour west of green bay.
what do you have?
8Nr--WI
04-12-2008 05:17:55
 Re: 6' disc---close to home in reply to award, 04-11-2008 13:51:28
Here is one right down the road from you.
HTH--Tim
8Nr--WI
04-11-2008 15:46:28
 Re: 7' Disc for Sale in reply to award, 04-11-2008 13:51:28
I don't have one for sale myself. The Baraboo disc is a nice disc---about $300 too much imho.
I know of 2 "antique" discs for sale.
Readstown, WI 8' Dearborn Flex-o-Hitch Lift Type for $300
La Crosse, WI 6' Love Tractor Co. Lift Type Disc. Needs Bearings---$175
If you want to travel that far, I will get you the name and phone # of the sellers.
Tim
Colin King
04-11-2008 08:33:53
 Re: king kutter disc bearing options ? in reply to award, 04-10-2008 22:11:37
I had the same problem here in Minnesota. Took me over a year to find one that was both reasonably priced and within transporting distance.
Good luck!
Colin
soundguy
04-10-2008 22:23:07
There are lots of implements I will buy used.. but a disc.. well.. sometimes it is just plain cheaper to buy new..
soundguy
