Reading spark plus – Hobo
Dan in CO
04-13-2008 09:31:53
In another post regarding carbon build up, I see Hobo has a link to a “reading spark plugs” article. I recently helped my neighbor out with his IH 540 that was running on 3 cylinders. When I pulled the plugs, this is what I found:
third party image
Hobo; can you tell me what is going on here? It kina looks to me like #2 (from the left) might be the problem.
Tom N MS
04-13-2008 18:17:36
 Re: Reading spark plus – Hobo in reply to Dan in CO, 04-13-2008 09:31:53
Check this out..
http://www.dansmc.com/spark_plugs/spark_plugs_catalog.html
garytomaszewski
04-13-2008 17:43:12
Does look like no.2 might be a problem. My really,REALLY old Champion full color chart doesn't match to many things any more. Lack of lead in gas???
Jerry/MT
04-13-2008 11:51:09
The other three plugs look like they are either running hot(too hot of a plug), the mixture is too lean or the timing a bit over advanced.
GB in MT.
04-13-2008 12:00:01
 Re: Reading spark plus – Hobo in reply to Jerry/MT, 04-13-2008 11:51:09
Hi Jerry;
I think you are close to being right. Those three look like running too lean or bad gas, and the really fowled one is bad/stuck ring or valve stuck open. Maybe even both on that one.!!!
Gary :?:
Dan in CO
04-13-2008 11:12:41
 Re: Reading spark plus – Hobo in reply to Lumpy, 04-13-2008 09:31:53
Hobo,NC said: (quoted from post at 12:11:49 04/13/08) Deposits
The accumulation of deposits on the firing end is influenced by oil leakage, fuel quality and the engine's operating duration
Oil rings shot
So, would the ATF soak help the oil rings? the tractor doesn't smoke at all so I thought oil burning was not the issue. Also, will hotter plugs keep them clean?
Hobo,NC
04-13-2008 10:11:49
Deposits
Oil rings shot
Bob Harvey
04-13-2008 09:47:01
My guess is bad rings or valve guides on #2. A hotter plug is a temp fix.
Joe in MI
04-13-2008 09:34:40
Unfortunately, that's what #4 looked like in my 8n when I bought it. Ran a lot better after I put in new AL 437 plugs. It still fouls that one after working it hard, though. I haven't let it get that bad again, though.
Joe
