Order Ford 8N Parts Online
Ford 8n p3 diesel
Paul Lawton
04-13-2008 14:36:48
Help!! I have a ford 8n which was converted to a perkins p3 diesel some many years ago, i am trying to date the tractor but as the engine has been changed the only numbers i can see are on the rear axles which say 8n 4012 B2 and 8n 4013 B2 does anyone know what these mean??
Dunk
04-14-2008 12:35:59
 Re: Ford 8n p3 diesel in reply to Paul Lawton, 04-13-2008 14:36:48
Also the clutch linkage, and I think the upper lift arms are the same as my '49, I think that will make it a '49 to early '52???
The others will know more...
Dunk
04-14-2008 12:29:12
The original parts, with the exception of the '67 Chevy II Nova (gas cap) tranny fill cap, the parts all match my '49 8N *236763* .
The steering gearbox, the gear shifter knob, etc.
soundguy
04-13-2008 18:22:11
Post some pics for us..
soundguy
Sean (TX)
04-13-2008 17:15:33
 Re: Ford 8n p3 diesel in reply to award, 04-13-2008 14:36:48
Paul Lawton said: (quoted from post at 16:36:48 04/13/08) Help!! I have a ford 8n which was converted to a perkins p3 diesel some many years ago, i am trying to date the tractor but as the engine has been changed the only numbers i can see are on the rear axles which say 8n 4012 B2 and 8n 4013 B2 does anyone know what these mean??
That is a pretty interesting conversion!!
third party imagethird party image
third party image
Paul Lawton
04-14-2008 12:00:52
 Re: Ford 8n p3 diesel in reply to Sean (TX), 04-13-2008 17:15:33
third party image
Hi thanks to all those who replied a picture link has been added. The ford looks in a pretty bad way but with a lot of tlc it will soon be on its way back to its former glory. The only strange thing i have found is that on the pto caseing it has a 9N part number, not sure why?
Joe in MI
04-13-2008 17:09:01
I think in 52 they changed the upper lift arms to a more rectangular cross section. There was also a "bump" on the left side of the tranny housing. That might confirm the 1952 guess.
Dell (WA)
04-13-2008 15:50:32
Paul..... ..8N-4012B2 is part number for RIGHT trumpet; 8N-4013B2 is part number for LEFT trumpet (1948-1952) sometimes there is an alpha-numeric "casting date" on the trumpets that we can help you decypher. More better, lie on ground and look at yer flat hydraulic pump plate for plain date around the corner pressure test port. Everything (except the Perkins Diesel) is readily replaceable at reasonable prices..... ...Dell
Ross Pugh(NC)
04-13-2008 14:50:02
WAG=1952
