points gap
k ohls
04-17-2008 12:33:13
can anyone tell me the points gap for a 49 8n
thanks so much
Dell (WA)
04-17-2008 13:00:29
 Re: points gap in reply to k ohls, 04-17-2008 12:33:13
k ohls..... ...the 1949 8N is a 4-nipple frontmount distributor that you remove (2-bolts, 15-min job) and adjust the points (0.015) on your kitchen table. The frontmount distributor is driven by an "off-set" tang scheme and can NOT be installed outta time. Just finger start the 2-bolts and twirl the rotor 'till it drops into place, then finish tightening 2-bolts. NO FORCE needed. Simple, eh?
The squarecan 1-terminal ignition coil is clippie mounted and needs the dangle'n springy-thingy stretched so it securely meets in the hollow-headed points screw.
You do NOT haffta remove the 4-nipple cap, just un-clippie and letter dangle..... .HTH, Dell yer self-appointed sparkie-meister
Colin King
04-17-2008 12:46:35
points are set to 0.015 and plugs are set to 0.025
If you don't have one, I strongly suggest that you pick up a I&T FO-4 repair manual for your 8N. It's an invaluable resource, and among other things, will show you how to time the front mount distributor.
You can support this forum by buying directly from this site.
Colin, MN
