2N spindles
Sean (TX)
04-17-2008 14:05:39
Im guessing this a farmers fix for worn axle extensions? This bolt stops the bushing from dropping down into the axle extension.
Jerk is on other side.
third party image
Shot of the bushing in the hole. Bolt stops it so it is flush to the top.
third party image
Cleaned up nice is it shot? Im guessing the bushing should be a tight fit? It just drops in. Do the bushings need to be reamed? wont easly slide over the spindle.
Sean (TX)
04-17-2008 17:52:38
 Re: 2N spindles in reply to Mark Lugo, 04-17-2008 14:05:39
JB Weld = Modern day farmer repair!!! :lol: 8) :lol:
Sean (TX)
04-17-2008 17:50:23
 Re: 2N spindles in reply to JMOR, 04-17-2008 14:05:39
Jb weld crossed my mind to....My guess would be to assemble while it is wet...That kit is cheap!!! Why do people run them into the ground!!
HCooke
04-17-2008 17:45:46
 Re: 2N spindles in reply to Sean (TX), 04-17-2008 14:05:39
My experience -- I had to replace an axle extension because of extreme wear (the axle was wallowed out) and a new bushing just dropped into the middle of the axle. Luckily I found a used one at reasonable cost. Always wondered it a new bushing could have been put in place with JB Weld. I'm not sure how you would get the geometry correct.
Jim G in WV
04-17-2008 16:38:44
The bolt looks like a farmer fix to me. It must have been used as a set screw to stop the bushing from moving around. I glued a loose bushing into the spindle housing with JB Weld on one of my tractors a couple of years ago. So far it has held. If I need to ream the bushings to get the spindle back in, I just use a wheel cylinder hone.
GB in MT.
04-17-2008 14:50:32
My 44, don't have that bolt, on either side. Both of mine have the grease zerk, but NO bolt.
You'll have to wait for someone smarter than me to answere that one!!!!! !
Gary :?
