Order Ford 8N Parts Online
Starting 8N Restoration
RichardR
04-17-2008 17:21:39
I recently bought my first Ford tractor and have started the disassembly. I will have a lot of questions as I progress so I appreciate any help that is offered. I have two questions to start: 1. It appears to have had it's engine replaced by one from a 9N. Are specs (and parts) the same for this engine as for the 8N? 2. The pin where the three-point arm attaches to the differential housing is turning when I try to remove the nut. Is it pressed in; what should I do?
Thanks,
Richard
Ed S. (IL)
04-18-2008 06:45:16
 Re: Starting 8N Restoration in reply to RichardR, 04-17-2008 17:21:39
I had to tighten my left pin, and pulled the trumpet to do it. I've also read where someone pulled the PTO shaft out the back and was able to reach in through the resulting hole to tighten.
Another photo for you - pin with castle nut is at 7 o'clock from the axle shaft:
third party image
The differential is heavy, but manageable to remove - it just slides off the axle shaft (only out the left side, tho).
Clean out your sump while you're in there.
es
Dunk
04-18-2008 06:02:41
Don't forget, the gaskets won't fit till you wet them a tad with water.
(Thanks, Dell)
Dunk
04-18-2008 06:01:24
I pulled both trumpets on mine, and left the HEAVY chunk sitting where it was when I replaced both of my lower lift pins after breaking the well worn right one.
I don't think my back would have handled the weight of the chunk very well, and I don't have a cherry picker.
third party image
osduck5
04-17-2008 17:46:06
Congradulations, I am not far ahead of you. I have mine partcially disassembled getting ready to paint. Best advice I can give you is to buy a IT shop manual FO-4. They are well worth the money. Also, take a camera and take some pictures so you will remember how everything came off or where it goes when you start putting it back together. My biggest decision right now is determining which color of gray and red I want to paint. Mine is going to be a working tractor but I want it to look good at the same time. Hope you enjoy the project.
Ken Crisman
04-17-2008 17:43:43
Hey, congratulations on being a new owner of a great little tractor . Apparantly the engine switch is the same becuae I've read of others doing it except they put 8n engines in 9ns . I had a 9n with an 8n engine in it . About the lift arm bolt turning , you'll have to pull the left rear trumpet off & get in there with a socket to tighten it or else replace it . They say its not possible to get at either side by removing the right trumpet . So again block the tractor up safely & remove the trumpet on the left side . There's another site devoted to Ntractors if you're interested in checking it out .I've gotten alot of help from those guys . So , hey check it out . If you send me your email address I can give you the website . Can't do it here because their filter kicks it out . Oh yea , ya wanna take pics of any repairs & restorations you do on your N . Also draw pics with notes for a reference . You'll be glad you did . HTH ! God bless , Ken
RichardR
04-17-2008 17:53:36
 Re: Starting 8N Restoration in reply to Ken Crisman, 04-17-2008 17:43:43
Thanks. Ken, my loose one is on the right side, so should I just pull the right trumpet?
Ken Crisman
04-17-2008 20:34:37
 Re: Starting 8N Restoration in reply to RichardR, 04-17-2008 17:53:36
No Richard , pull the left trumpet only for both bolts . What they are is a double threaded bolt that is inserted into the housing with a seal, washer & nut on the inside . Either that seal has deteriated or the nut has just loosened . Or , worse cenario , it could be the bolt is worn out . HTH ! God bless, Ken
tooltime
04-17-2008 18:00:40
you want to pull the left side for repairing the left or right side. do not remove right side, trust me. Jim
tooltime
04-17-2008 18:19:40
 Re: Starting 8N Restoration in reply to tooltime, 04-17-2008 18:00:40
third party image
here is a picture, and you can see the castle nut YOU CAN TIGHTEN OR REPLACE.
RichardR
04-17-2008 18:22:15
 Re: Starting 8N Restoration in reply to tooltime, 04-17-2008 18:19:40
Do you have to remove the differential? Is that difficult?
tooltime
04-17-2008 18:47:44
 Re: Starting 8N Restoration in reply to RichardR, 04-17-2008 18:22:15
you can get in there without pulling diffy. the lower link pin castle nutt is low enough, just take your time. once you have the trumpet apart from tractor you can see what needs to be done.
RichardR
04-17-2008 19:04:29
 Re: Starting 8N Restoration in reply to tooltime, 04-17-2008 18:47:44
Thanks, Jim. Will do.
tooltime
04-17-2008 19:16:25
 Re: Starting 8N Restoration in reply to RichardR, 04-17-2008 19:04:29
congrats on the ford. take your time, ask questions, you are a owner of a great tractor with tons of history!
