Order Ford 8N Parts Online
6 volt - front mount 8n Wiring diagram
nondem
04-17-2008 17:38:02
The diagram I'm finding everywhere is the one for the late-1950+ 8n.
I've got the older 1950 model w/front mount. The diagram for the late 50's is fine for 90% of the wiring but there is a resistor under the Ammeter that is apparently merged with the terminal block and differences with the coil wiring.
Is there a diagram for my application online somewhere?
Also, if there is a resistor wired in series with my coil lead coming from the keyswitch - does that mean the current coil(external round) is a 12v? I'll be switching back to a new front mounted coil but I currently have an "altered" 6v external setup.
nondem
04-18-2008 06:00:55
 Re: 6 volt - front mount 8n Wiring diagram in reply to JMOR, 04-17-2008 17:38:02
souNdguy said: (quoted from post at 23:00:56 04/17/08) to step 6v down to 3v for the weak sister square coil.
soundguy
So do I still need the resistor someone installed in series with the 6v round coil? If I use the OEM dash-mounted resistor & the one "someone" installed near the coil that would reduce the voltage to much right?
So if thats the case - I need to only have one of the resistors in between the coil and the ignition. Which would mean I could just connect the hot(coil) wire to the other side of the dash resistor which would give it power w/o going through the dash mounted one...
Maybe a should take some pics....
nondem
04-17-2008 18:54:32
 Re: 6 volt - front mount 8n Wiring diagram in reply to Bob Maling, 04-17-2008 17:38:02
OK - it just dawned on me that a resistor isn't gonna step 6v "UP" to 12v so Obviously it's a 6v coil. So why the resistor?
souNdguy
04-17-2008 20:00:56
 Re: 6 volt - front mount 8n Wiring diagram in reply to nondem, 04-17-2008 18:54:32
soundguy
nondem
04-17-2008 18:42:38
I think so - I found that one right after posting by using 9n instead of 8...
jon
04-17-2008 18:11:06
 Re: 6 volt - front mount 8n Wiring diagram in reply to nondem, 04-17-2008 17:38:02
This it? third party image
