Dell, Bob, Others, Resistor Why
Dunk
04-18-2008 12:10:27
Ok, Seems the popular consensus is that with the 12v, or 6v, round can coils, there is no need for a resistor.
Why did '70s models and earlier cars have them with the 12v, and 6v, round can coils?
I know Chrysler/Dodge did, Chevy used resistance wire to the coil from the switch.
What am I missing here?
Dunk
04-18-2008 12:50:53
 Re: Dell, Bob, Others, Resistor Why in reply to Dunk, 04-18-2008 12:10:27
Dell, That makes very good sense.
Thanks!!
Dell (WA)
04-18-2008 12:44:19
Dunk..... ...them 70's were using the same frontmount squarecan ignition coil trick.
Bypass the resistor with special starter solenoid contacts during start-up. Start-up can really drag a battery down, its a chemical reaction thing. While you think yer battery is providing 12v to yer starter, it really mightbe dragged down to 8-volts. 8v on a 12-volt coil ain't gonna gittcha hott-enuff sparkies to sparkle.
So by essentially using a coil designed for 8v (say) and protecting it by an external resistor that is switched out when starting, you gitt hott-enuff sparkies for starting HI-COMPRESSION engines of the 70's. Then when you lett-upp on yer twist-to-start ignition yer already running engine will continue to run on because the solenoid ...or... ignition switch as re-inserted this necessary 12-to-8v resistance in the coil circuit.
Basically, its cheaper to do electrical "tricks" than use a bigg-enuff battery that won't drag-down for just that 1-min of starting time.
Now then, because of EMISSION law requirements, most sparkie systems have been transistorized and HOTTED-UP to meet gov't regulations for SMOG and LONG LIFE. And the redesign makes automatic solidstate allowances for loaded battery problems. Sometimes bureaucrats are semi-helpful..... ...Dell
