One way to get the bow out
Sean (TX)
04-19-2008 09:40:55
Worked..
third party image
Dunk
04-19-2008 19:39:17
 Re: One way to get the bow out in reply to Dell (WA), 04-19-2008 09:40:55
Sean (TX) said: (quoted from post at 23:08:07 04/19/08)
Tom N MS said: (quoted from post at 20:43:58 04/19/08) No way to explain that one and make it make any sense. Twisting on stuff that ain't suppose to be twisted on like that. Go for it with yours but never never on mine..Just not good and can't be explained into a good thing...
Its been done before!! Cant use heat the steel is tempered. I have read about another method and you need a 4' pipe wrench and twist the front axle :lol:
You did it the way I would have done it.
Sean (TX)
04-19-2008 19:08:07
 Re: One way to get the bow out in reply to Mikey Ford ???N, 04-19-2008 09:40:55
GA Dave
04-19-2008 18:42:30
 Re: One way to get the bow out in reply to Sean (TX), 04-19-2008 09:40:55
Did a 1969 Ford F100 twin I beam once. Had to use a little heat though. What we can't think of!!!!! David.
Hobo,NC
04-19-2008 18:23:00
Yer smarter than a mule and yer head ain't haf as big
Dell (WA)
04-19-2008 14:23:42
Sean..... ...remember you haffta go PAST straight 'cuz the metal with "bounce back" some when you remove the pressure.
BTW, Zane has posted his "straightening" technique several times. Its SIMILAR to yers ..... .Dell
Sean (TX)
04-19-2008 13:35:42
 Re: One way to get the bow out in reply to Jack L, 04-19-2008 09:40:55
Go ahead. That 4x12 sure has come in handy.
Empennage
04-19-2008 13:28:11
Pure genius.
Mind if I use your idea?
Dan in CO
04-19-2008 11:29:20
Sean:
You must be an Engineer to come up with that!
Good stuff.
Sean (TX)
04-19-2008 10:27:28
 Re: One way to get the bow out in reply to Joe)NYC), 04-19-2008 09:40:55
I have a bumper crop!!!
Tom N MS
04-19-2008 10:17:35
As long as it works. I am going to do something similar or probably take them to work and invite the maint. guys to see if they can straighten them on our press. Not sure if it has the side openings but i bet it will work with enough rigging. I'll leave them bent before I go twisting with a 4' pipe wrench and come-along as some suggest.No way can that be good for the front axle, trumpet or anything else involved...
ZANE
04-19-2008 18:33:17
 Re: One way to get the bow out in reply to Tom N MS, 04-19-2008 10:17:35
Oh yea of little faith!
Zane
Tom N MS
04-19-2008 18:43:58
 Re: One way to get the bow out in reply to ZANE, 04-19-2008 18:33:17
HCooke
04-19-2008 10:16:20
Looks good. PS I didn't think anyone had rockier ground than I do but yours is real close.
