Cam Shaft? Click
9n
04-19-2008 09:48:07
We ran into a problem in the 9n project. It seems like the camshaft is clicking...
I get a click when cylinder 1 is at top and bottom (two per cycle). When I tried to locate the click, i felt the cam shaft and it is jumping out as it clicks.
Any Ideas on how to fix this problem? I have included a video, hopefully it works.
Thanks a ton
Dunk
04-19-2008 19:36:07
 Re: Cam Shaft? Click in reply to 9n, 04-19-2008 09:48:07
I too am with gaspump.
Only turn your engine one way.
Clockwise.
This statement gets worse in the later years, when you git into DOHC and toothed rubber belts.
Hobo,NC
04-19-2008 19:05:26
Gaspump is rite on track,,, its not uncommon to get a pop/click from the cam moving in and out when assembling the engine
The first one I herd do that I could not believe what I was hearing...
Gaspump
04-19-2008 11:16:04
Don't use turning the crank back and forth for a test as you are doing, the gears climb the angle and go back and will likely make the noise you are hearing. The engine turns the same direction, always, try turning the crank continuously clockwise from the front and see what happens. Also the cover and washer will dampen movement some.
