nondem..... ...it ain'chur coil, its yer springy-thingy. It ain't connecting with yer points. Thats one of the troubles with the 4-nipple frontmount roundcan coil conversion, where the springy-thingy is supposed to touch the hollow headed condenser screw with authority, it don't 'cuz you probably ain't gottta a springy-thingy or it is twisted off to the side. Infact, that is also the same problem with using the squarecan coil, the danglin' springy-thingy. You do know its a 2-bolt, 15-min job to REMOVE yer frontmount distributor and change the points (gap = 0.015") on the kitchen table, don't you? The frontmount distributor is driven by an "off-sett" slot drive scheme and you cannot install outta time without breaking sumptin. Just finger start the 2-bolts and then twirl the rotor until it drops in, now tighten yer 2-bolts. Simple, eh? ..... ...Dell, yer self-appointed sparkie-meister
