Second hat rim is done
Sean (TX)
04-19-2008 16:51:08
Along with both disks and I treated them with ospho. Someone welded a piece of pipe around the valve stem on this one. A really nice bead :)
third party image
third party image
third party image
Sean (TX)
04-20-2008 06:12:17
 Re: Second hat rim is done in reply to Pappy, 04-19-2008 16:51:08
Lumpy said: (quoted from post at 08:06:02 04/20/08) A stupid question, but I gotta ask.... what is ospho? I have never heard of it.
Ospho Rust Treatment - Since 1947
Lumpy
04-20-2008 06:06:02
 Re: Second hat rim is done in reply to Sean (TX), 04-19-2008 16:51:08
Lumpy
04-20-2008 06:03:45
Sean, Thanks for posting the pics of the 2 center discs bolted togther for a dual wheel set-up. Appreciate you going to all the work. Thanks!
Sean (TX)
04-19-2008 17:18:24
 Re: Second hat rim is done in reply to award, 04-19-2008 16:51:08
Pretty good idea. Keeps them safe and the mud and dirt out..
DON TX
04-19-2008 20:36:22
 Re: Second hat rim is done in reply to Sean (TX), 04-19-2008 17:18:24
I have 2 rims with the stem protectors, unfortunately they rusted so bad 1 has popped the tube. They were turned to the inside and made it hard to put air in them. I've got a set of hat rims to sandblast myself. The painted galvanize is still in good shape with a little surface rust in areas. May try a brass wire brush first just to see if I can save the galvanizing.
DON TX
sgt bull
04-20-2008 04:57:59
 Re: Second hat rim is done in reply to DON TX, 04-19-2008 20:36:22
I"ve got ONE extra stem protector... (no idea where the other went.) If you"re interested, $5 and postage.
Sean (TX)
04-19-2008 17:05:39
 Re: Second hat rim is done in reply to Dell (WA), 04-19-2008 16:51:08
They are in nice condition. They never had CACL in them :) Plus the leaky axle seals gave them a nice coat of GL1. Did a nice job of preserving them. Fred was worth every penny I paid for him..
Den N Ms
04-19-2008 17:13:22
 Re: Second hat rim is done in reply to Sean (TX), 04-19-2008 17:05:39
I saw a fellow have a welding shop to weld on 2" threaded black pipe and had pipe caps on them like that several years ago.
Den N Ms
04-19-2008 16:58:09
Sean,It looks like those hat rims are in good shape,not rusted away.Lookin Good.
Den N Ms
04-19-2008 17:01:40
 Re: Second hat rim is done in reply to Den N Ms, 04-19-2008 16:58:09
That old farmer didn't want to knock another valve stem off that wheel again did he.
