Hood Rubber Grommets
RD TX
04-21-2008 04:52:13
Does anyone know where I can buy the rubber grommets for the bottom bolts on the hood?
Thanks,
RD
KCM
04-21-2008 09:38:14
 Re: Hood Rubber Grommets in reply to RD TX, 04-21-2008 04:52:13
Are you talking about the bolts at the bottom of the "doglegs"? If so, there are no rubber grommets there.
RD TX
04-21-2008 11:32:42
 Re: Hood Rubber Grommets in reply to KCM, 04-21-2008 09:38:14
yes when I pulled off the hood the bolt on one side was gone and the other had a thick round rubber approximately 1/2 inch think and another one about the size of a silver dollar.
RD
KCM
04-22-2008 06:49:52
 Re: Hood Rubber Grommets in reply to RD TX, 04-21-2008 11:32:42
Must have been farmerized. There should only be a bolt and washer with a nut on the inside to screw into. Only rubber I can think of down there would be on the radiator mount bolts, between the radiator and mount. And I believe that was a cloth-like material originally, and not near 1/2" thick.
RD TX
04-21-2008 04:52:50
Sorry that would be for a 2N.
RD
boltman
04-29-2008 20:02:46
 Re: Hood Rubber Grommets in reply to RD TX, 04-21-2008 04:52:50
IF YOU HAVENT FOUND THEM YET AND ARE STILL LOOKING CHECK OUT THE FOLLOWING WEBSITE Link THEY HAVE THEM AND MANY OTHER GOODIES YOU MAY NEED. GOOD LUCK
