Order Ford 8N Parts Online
Dearborn 19-61 Loader on a 8N
Ron Blickenstaf
04-21-2008 07:53:57
Has any one ever mounted a Dearborn 19-61 on a Ford 8N, the assy. instructions say its made for a Ford NAA. Any help or pictures would be grea
EdB
04-22-2008 06:17:12
 Re: Dearborn 19-61 Loader on a 8N in reply to Ron Blickenstaff, 04-21-2008 07:53:57
I mounted a 19-61 on my 8N by fabricating new mounts. Because of the shorter length of the 8N the rear loader mounts need to be longer to the rear of the tractor. Since this was a one time use of the loader I didn't want to disassemble the front end and got around it by fabricating a front mount designed after the wagner style mounts. They just bolt to the heavy press steel motor mount at the front.
EdB
04-22-2008 06:17:07
EdB
04-22-2008 06:17:05
TheOldHokie
04-21-2008 10:07:27
Ron Blickenstaff said: (quoted from post at 07:53:57 04/21/08)
Aside from the difference in length the front hanger used on the NAA may not fit the 8N. ISTR seeing a post here recently that had a picture of that hanger on an N but I can't seem to find it now. I suspect it will only require a small bit of creative fabrication to adapt the loader to an N.
Here's a picture from the dealer parts book showing the NAA front bracket (top inset) and the N series bracket (below it). The parts list indicates the N series bracket was only for use on the 19-22/23 loader.
TOH
third party image
