1) did I fry diodes in alternator or do other damage? ...Take the alternator in and have it tested, as it's likely damaged after that much smoke was let out of the witing. OR, with the battery connected up PROPERLY, touch the large alternator output wire terminal to the output stud. BIG spark = shorted diodes. NO spark = MAYBE the alternator will charge when you fire up the engine. 2) in the process of replacing melted wires the strap that links the ammeter posts came lose (the alternator side post detached from the alternator...so what role does the ammeter provide besides reading amps (which it never has)?
...There is a shunt between the two posts on the ammeter that allows current to flow between them, connecting the power from the battery onward to the terminal block. If the ammeter is still "in circuit", whether or not the ammeter still "reads" or is stuck, it needs to be there to complete the circuit from the battery-powered terminal on the starter solenoid to the junction block. 3) I"m getting no spark, and I traced it back to no juice at the terminal where the wire to the coil takes off... ...See answer to #4. 4) it could be further screwed up by the fact that I replaced the busted ammeter with a volt meter...so maybe that is the reason for #4?? IF you directly replaced the ammeter with a voltmeter, (connected it to the existing wiring) you will have negligible current to the terminal block, and on to the ignition switch, as the coil in the VOLTMETER has a very high resistance, compared to the AMMETER, (with a lo resistance SHUNT across it's terminals) that's suppose to be there. The VOLTMETER would need to be connected between the SWITCHED side of the ignition switch and GROUND. This puts a little voltage drop into the voltmeter reading, compared to the voltage at the battery, but the power to the VOLTMETER has to be SWITCHED, or it will be a (small) constant drain on the battery any time the tractor is sitting unused.
