Gas in the Crankcase
Ron Morris
04-22-2008 14:33:19
While waiting on my carb rebuild kit, I decided to change the oil. It was full of fuel. I know how it got there (fuel left on,drain plugged,dirty carb etc.) but now I am wondering if just changing the oil will be enough. I don't want to run it and burn something up. Any suggestions other than a few oil changes? Thanks.
ZANE
04-22-2008 16:52:56
 Re: Gas in the Crankcase in reply to Ron Morris, 04-22-2008 14:33:19
It is very possible that you have a liquid lock on one or more cylinder. Don't try to pull the tractor if it doesn't want to turn over with the starter. Remove the plugs and then gently pull it a few feet. Do not under any circumstance turn on the ignition!!!!! Better to disconnect the battery to prevent accidental spark. A tractor on fire is not a nice thing to witness.
Zane
Bob Harvey
04-22-2008 20:06:58
 Re: Gas in the Crankcase in reply to ZANE, 04-22-2008 16:52:56
Damm straight, do as Zane says. Tractor fires are NOT pretty. BTDT....ugh
RP-40-9n
04-22-2008 15:48:02
ron, change the oil and filter and have fun. thats all that is necessary. the few drops of gas in the system wii evaporate very quick. RP
36 coupe
04-22-2008 16:31:03
 Re: Gas in the Crankcase in reply to RP-40-9n, 04-22-2008 15:48:02
All gas in the tank can end up in the crank case.NEVER leave the gas turned on when the tractor is parked.
Ron Morris
04-22-2008 16:24:36
I thought it may be ok but I always like a second opinion. Thanks!
