Autolite plugs
Phippsburgh
04-23-2008 19:42:22
My 8N came with Autolite 216 Plugs.25 to 30 thousanths gap. It has been converted to 12v. Are these kosher for my application?
LeeMo
04-24-2008 09:09:20
 Re: Autolite plugs in reply to Phippsburgh, 04-23-2008 19:42:22
Those are the original spec plugs. Like the others indicated the AL437s seem to give better service.
Dell (WA)
04-23-2008 20:55:09
Phippsie..... ..we recommend with modern no-lead gasoline to use the hotter AutoLite 437's gapped 0.025"
Try NOT to let yer sparkie gap gitt too wide 'cuz yer ignition coil ain't really gottz enuff spare sparkie volts to jump wider gaps as ignition systems wear from normal operation.
While the original 1939 sparkie was specified as the cooler Champion H10, modern Champions don't really do well in N-Engines with no-lead gas fer some reason..... ...Dell, yer self-appointed sparkie-meister
Dunk
04-23-2008 19:49:43
 Re: Autolite plugs in reply to nasty n tx, 04-23-2008 19:42:22
Phippsburgh said: (quoted from post at 23:42:22 04/23/08) My 8N came with Autolite 216 Plugs.25 to 30 thousanths gap. It has been converted to 12v. Are these kosher for my application?
Do check out Bruce's tips for what is recommended.
Link
