Oil Change instructions:
Dan in CO
04-24-2008 19:29:43
1) Wait until Saturday, drive to auto parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
2) Stop by 7/11 and buy a case of beer, write a check for $20, drive home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench.
15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
16) Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties. Drink a beer.
17) Install new oil filter making sure to apply a thin coat of oil to gasket surface.
18) Dump first quart of fresh oil into engine.
19) Remember drain plug from step 11.
20) Hurry to find drain plug in drain pan.21) Drink beer.
22) Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
23) Get drain plug back in with only a minor spill. Drink beer.
24) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame removing any excess skin between knuckles and frame.
25) Begin cussing fit.
26) Throw stupid crescent wrench.
27) Cuss for additional 5 minutes because wrench hit bowling trophy.
28) Beer.
29) Clean up hands and bandage as required to stop blood flow.
30) Beer.
31) Dump in five fresh quarts of oil.
32) Beer.
33) Lower car from jack stands.
34) Move car back to apply more kitty litter to fresh oil spilled during any missed steps.
35) Beer.
36) Test drive car.
37) Get pulled over: arrested for driving under the influence.
38) Car gets impounded.
39) Call loving wife, make bail.
40) 12 hours later, get car from impound yard.
Money spent:
Parts: $50.00
DUI: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $20.00
Total: $4,145.00
But you know the job was done right!
BillM (OH)
04-24-2008 20:12:25
 Re: Oil Change instructions: in reply to Dan in CO, 04-24-2008 19:29:43
Well, I didn't experience the DUI part, but will add:
1. Overtighten drain plug and break nut spot welded in two places inside oil pan.
2. Spot weld break tears hole in oil pan.
3. Drink coupla beers deciding if enough guts to weld on oil pan...decide maybe not.
4. Call dealer to ask for estimate on fix - sez must drop entire 4wd front X, etc. to get oil pan off & will cost BIG $$$. 5. Know dealer lies and is trying to get rich - way to remove oil pan is jack engine off mounts and take off.
6. Coupla more beers working up guts enough to put welder to oil pan still on truck.
7. Fire up welder and plug hole - no fire on rest of truck.
8. Take cold chisel and break off rest of broken nut inside oil pan.
9. Weld up other hole.
10. Go to NAPA and get rubber expansion plug for oil pan drain hole & install.
11. Install new filter.
12. Put in oil
13. Rubber plug still on truck working fine years later when sold.
True story!!!
osduck5
04-24-2008 19:36:17
Sounds a bad as me trying to repair garage door spring. Almost cut my finger off. After paying emergency room bill, I could have bought complete door and had professional hang it for less money!!
