Hey Guys -My dad's NAA Jubilee will be at my house next weekend and my son & I am planning on fixing numerous projects on it for him, then repainting it for him. I have some background in the F-series Farmalls, but not much in Fords. After the tractor gets here, I plan to do a analysis on it to find out exactly what work it needs before we get to the paint process, them plan the repairs accordingly. Questions for today are: 1) What wet/dry compression results should it exhibit? How much variation between each cylinder is OK ? 2) The throttle is operating wierdly. Engine speed is controlled fair in the lower speed range, but zips up to full speed very quickly at about mid-throttle range. Govenor also does not like to respond to a load anymore. Thoughts here? 3) Am getting some white smoke after the engine warms up, and he is losing some coolant. Oil never appears to get milky, thus it appears the coolant is leaking into the combustion chamber from a leaky head gasket or a cracked head. Any tell tales of a leaky head or gasket? 4) The tractor used to have a stubby muffler that resided above the manifold and discharged behind the headlight. Dad put a system on it that discharges behind the rear axle. This system has the tube 50% collapsed near the fan area. I am assuming this situation isn't too good for engine back pressure. Any body have any experience with these systems ? 5) Engine used to start at the slightest touch of the starter with no choke. Engine now won't start unless the throttle is parked wide open. Thoughts here? 6) The 3-point bounces every several seconds while a load hangs on it. I am assuming the piston is leaking, and from what I've heard, it is because the open ended cylinder is flaring outwards. Is this cylinder repairable or should it simply be replaced? More questions will be coming later as we get into the tractor. Thanks for your wisdom ! Pete
