Doggie..... ..ya want dependablity? gitta Yammabottadeereee diesel. $$$$ with power steering and live hydro and FEL Ya want affordability? Iff'n you can't do it, then have yer carb professionally rebuilt. DO NOT recarb with ZENITH. (my opinion only) The M/S is eminently rebuildable. $250 tops. Full kit is just $40 (cheap) Iff'n yer an electronically challenged shadetree mechanic, hire yer electronic conversions done. $250 tops. New points just $15 (cheap) Change yer weaksister ignition switch. $15 (cheap) will fixx yer weak sparkies. The M/S is not hard to correctly adjust. Both Ford and M/S say to adjust both the side-pointing idlemix and down-pointing mainjet to 1-turn. That is just a starting point. Much to the dismay of gov't smog bureaucrats each and every carb must be individually adjusted to the its specific engine. I set the down-pointing mainjet to 2-turns and LEAVITTT!!!! I then adjust the side-pointing idlemix for maximum idle rpms, NOT SMOOTHEST, max idle. I then adjust the behind the carb idle-speed to an incredibly SLOOOooow 400rpms. (ennythang under 500rpms is probably close) I do the idlemix and speed song'n'dance at least 3-times; always adjust for max idle speed, NOT smoothest. UNDERSTAND??? Remember the side-pointing idlemix is BASSACKWARDS; out for lean, IN for ENRICH. The last time I adjusted my eazy starting 6-volt 52-8N, my idlemix was 1/4-turn and idlespeed was 410rpms. Yours should be similar. Simple, eh?..... ..respectfully, Dell
