adding hydrolic to Dearborn loader
Rich Walker
04-30-2008 11:57:33
Where is the fill plug? on the loader frame or the valve housing? I never got a manual with the 8N.
TheOldHokie
04-30-2008 14:00:00
 Re: adding hydrolic to Dearborn loader in reply to Rich Walker, 04-30-2008 11:57:33
Rich Walker said: (quoted from post at 11:57:33 04/30/08) Where is the fill plug? on the loader frame or the valve housing? I never got a manual with the 8N.
Most of the manuals are available for free on "the other site". What model is the loader and I'll check their list of manuals if you don't know how to get to them.
TOH
old
04-30-2008 13:13:06
A lot depends on which model it is. Some are on the center cross beam and some are on the side of the frame. Just look it over and find a pipe plug. When you find it that should be the fill point. There also maybe one down low as a drain that is not it
ArleninOr
04-30-2008 13:02:25
High point on loader frame just ahead of valve on rt side
