OT: 1987 BMW 325
Dan in CO
04-30-2008 16:33:27
I am trying to help out the neighbor in getting a 1987 BMW 325 running. It has been sitting for 2 years & the last time it ran he couldn’t re-start, so he parked it. There is no spark to the plugs. I have replaced the rotor & cap but still no spark at the plugs. I have tested one of the plug wires for continuity & get none. Is it possible that all of the plug wires have deteriorated to the point that they show no continuity? Is there something else I should be looking for? I have 12V at the coil with the ignition on, but no current gets to the plugs. Any suggestions will be greatly appreciated.
kossuth
05-01-2008 08:36:39
 Re: OT: 1987 BMW 325 in reply to Dan in CO, 04-30-2008 16:33:27
Like others have said it sounds like the pickup assembly inside the distributer is bad. Not sure how that little beast is setup but I imagine it has some sorta trigger system or something like that that fires off the coil into the rotor which goes out your distro cap.
Colin King
05-01-2008 08:14:07
Did you check the coil to distributor wire?
Colin
Hobo,NC
04-30-2008 19:23:06
it will bring $12 a hundred at the scrap yard,,, mite b his best out,,, did I mention i would rather have a case of the clap than a BMW,,, don't take me wrong,,, well,,,,, I just don't like'em
gahorN
04-30-2008 21:43:17
 Re: OT: 1987 BMW 325 in reply to Hobo,NC, 04-30-2008 19:23:06
Well then, I certainly hope you get the k-l-a-p then. (grin.... sorry... just couldn't resist) :lol:
(I've gotten to where I hate all foreign cars. I don't care if they DO assemble a few over here.... The money still goes OVER THERE where it does very little to help our fellow citizens.
Dan in CO
04-30-2008 17:20:39
 Re: OT: 1987 BMW 325 in reply to Den N Ms, 04-30-2008 16:33:27
I didn't see a "pickup coil" inside the distributor. The condenser seemed to be built into the rotor. Did I miss it?
Den N Ms
04-30-2008 16:50:05
Dan,I would check the little pickup coil inside the distributor.You can check it with a ohm meter,or pull it out and take it to auto parts store for a free check.Remember the plug wires are resistor wires.
