Sean; How's Fred doing?
Dan in CO
05-02-2008 19:02:19
Been a few days since we have seen how Fred is doing. Any progress? any new pictures?
Sean (TX)
05-03-2008 16:38:55
 Re: Sean; How's Fred doing? in reply to Empennage, 05-02-2008 19:02:19
Well mowing the 10 acre camp ground was put off till next Friday.
Got some work done on Fred.
Had to remove the brake shaft so I could replace the brake backing plates.
Found some replacement collars at TSC. The originals were riveted on the brake shaft. I destroyed them when I removed them :lol:
New collar. It has a set screw and I put loctite on the threads..
third party image
BBQ for the brake shoes and some brake cleaner :lol: Left side was oil soaked...Right side the sure seal was doing its job. Going to clean that side sunday and put the right axle back in.
Shot of the left side on the old brake backing plate.
third party image
Axle back in place :D
third party image
I will get a couple shots of the sure seal install on thhe left side. I took a angle grinder to the seal and hammered it in...
Ed S. (IL)
05-03-2008 05:20:01
 Re: Sean; How's Fred doing? in reply to Dan in CO, 05-02-2008 19:02:19
You and I are in the same boat... The pile of small parts to be cleaned and painted is a bit daunting (some would say depressing).
es
Sean (TX)
05-02-2008 19:39:21
 Re: Sean; How's Fred doing? in reply to soundguy, 05-02-2008 19:02:19
Its still standing and we have had some high winds 8)
Sean (TX)
05-02-2008 19:32:45
 Re: Sean; How's Fred doing? in reply to Steve MI, 05-02-2008 19:02:19
I do have quite a few parts that are ready for primer...Need to prep the rest and prime everything at once...
Sean (TX)
05-02-2008 19:30:56
 Re: Sean; How's Fred doing? in reply to Upper Peninsula,Mi., 05-02-2008 19:02:19
No new pics...Not much progress...Had to get some work done on my brush hog...Got 10 acres i need to mow with the 9N (still No Name) Going to earn some parts money :D 8) Seat time :D
Gary,kansas
05-02-2008 19:33:48
 Re: Sean; How's Fred doing? in reply to Sean (TX), 05-02-2008 19:30:56
I want to know with the weather this spring, hows Fred's shed?
