slop in right steering sector
Jason Moore
05-02-2008 19:36:40
i adjusted the left steering sector and took all the slack out of the gears, but when i went to do the right side, there was no adjustment there. so i pulled the right hand stearing gear out and it appears to be ok. is there anything else i should look at that may be causing the slop only on the right side of my steering?
souNdguy
05-02-2008 22:09:57
 Re: slop in right steering sector in reply to Jason Moore, 05-02-2008 19:36:40
Is this an old style box on an 8n? ( you don't give very many details.. we don't charge by the word here.. the more info you give us, the better answers you get. ).
If it is as I guessed, it could be the bushings are too worn to get any adjustment out of rotating the side cover..
soundguy
Jason Moore
05-03-2008 18:43:30
 Re: slop in right steering sector in reply to souNdguy, 05-02-2008 22:09:57
it is the old style, it has four bolts that you remove and you turn the pitman arm retainer clockwise. so if the bushing is to worn to get any more adjustment out of, what is the procedure for replacing the bushing? do i have to remove the steering gear box from the tractor or can i just pull out the gearshaft that the right hand pitman arm is attached to and access it there.
soundguy
05-03-2008 21:26:14
 Re: slop in right steering sector in reply to Jason Moore, 05-03-2008 18:43:30
You can do much of the R&R on the tractor.. however if you have to service the lower bearing race.. the box needs to be pulled. Get a copy of the I&T fo-4 manual.. there is a great step by step recipe for R&R of the 2 gearbox types on the 8n.. helps you get it all buttoned back up and timed right. ( the steering box is not a hard job.. many of us here have rebuilt ours.. )
Soundguy
Jason Moore
05-04-2008 17:06:02
 Re: slop in right steering sector in reply to soundguy, 05-03-2008 21:26:14
thanks for your input, where can i get the I&T fo-4 manual?
soundguy
05-05-2008 04:34:43
 Re: slop in right steering sector in reply to Jason Moore, 05-04-2008 17:06:02
You can buy a copy from the parts section right here on this site.
soundguy
8N I&T Aftermarket Shop Repair Manual 152 Pages (Part No: FO-4)
