From my personal experience, the #1 problem w/ no fire on a frontmount is the misalignment of 55+ year old parts, not the failure of those parts. You are probably no older than me, so go to Wally World & get a $15 analog multi-meter. It is not that hard to use. First, check for continuity inside the distributor w/ the meter. It is very easy to ground the tip of the condenser wire to the body of the distributor when you replaced the points. Also, make sure the condenser wire does not go through the same opening in the distributor that the coil pig tail does. The condenser wire goes the opening on the top right. Look at the points; are they burned, pitted or mis-aligned? Check the point gap, .015 on all four lobes. Points do slip closed! Make sure you have the star washers under the screws on the points. Next, with the distributor still off the tractor, install the coil. Look at the pigtail on the coil; is it touching the brass screw inside of the distributor? Don’t trust your eyes; test for continuity from the top of the coil to the points. If you do not have continuity, stretch the pigtail a bit until you do. (some people would rather put a small washer under the brass screw) Look at the little tab opposite of the pigtail; bend it a bit also to insure that it will contact the distributor cap. At this point, I just put the distributor, coil & cap all back on the tractor as a unit (it helps to loosen the fan belt). The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem. Post back w/ results & any other questions.
