Need part ID & install location
Ed S. (IL)
05-03-2008 18:42:46
This little part was on one of my engine-to-transmission bolts, but I didn't mark where it goes. Not sure what it's supposed to do - maybe a place to hook a spring or run a wire through?
Can anyone ID the part and tell me which bolt it goes on (photo would be great)?
third party image
es
Dunk
05-03-2008 19:16:04
 Re: Need part ID install location in reply to Dan in CO, 05-03-2008 18:42:46
8N'r--WI said: (quoted from post at 23:12:22 05/03/08) Dunk--I don't know---you are right---pictures are of the right side when sitting in the tractor seat.
Your "11:00" reference should actually be the "1:00" bolt hole---from the tractor seat.
Maybe just a different "time zone"---:>)
Tim
No!!!!
You are right!!!
I'm left handed!!!
I do have issues with the right handed world.
The scroll bars on my Windows Mobile PDA suck!!
I can't see what I am doing for my hand in the way...
1:00 setting on the seat.
Ed S. (IL)
05-03-2008 19:13:29
 Re: Need part ID install location in reply to Ed S. (IL), 05-03-2008 18:42:46
Perfect - thanks for the ID and photos!
es
Dunk
05-03-2008 19:13:00
Sean (TX) said: (quoted from post at 23:11:23 05/03/08)
Dunk said: (quoted from post at 21:07:59 05/03/08) Nevermind, I am probably that F'UP.
what are you drinking and or smoking 8) :lol:
I would be more than happy to share with you, Sean.
Sean (TX)
05-03-2008 19:11:23
 Re: Need part ID install location in reply to lenray, 05-03-2008 18:42:46
Dunk
05-03-2008 19:07:59
Dunk
05-03-2008 19:06:40
 Re: Need part ID install location in reply to Dell (WA), 05-03-2008 18:42:46
Tim, am I that F'ed up, or why do your pictures look like from the wrong side?
8N'r--WI
05-03-2008 19:12:22
 Re: Need part ID install location in reply to Dunk, 05-03-2008 19:06:40
Tim
Dunk
05-03-2008 19:04:41
 Re: Need part ID & install location in reply to Bob in Tennessee, 05-03-2008 18:42:46
It holds a spring that goes to the throttle, right hand side if you are looking from settin in the seat.
about the 11:00 bolt.
8N'r--WI
05-03-2008 19:03:18
Ed--the part holds one end of the throttle rod return spring. It attaches to the bolt closest to the flywheel inspection port cover.
third party image
third party image
Tim
