Order Ford 8N Parts Online
Operation 8N: Engine On!
Ed S. (IL)
05-03-2008 18:48:33
third party image
es
Sean (TX)
05-03-2008 19:29:05
 Re: Operation 8N: Engine On! in reply to Dan, 05-03-2008 18:48:33
Torch got my radius arm pin out. May work on the king pin too...My king pin came out with too fingers....Had a plastic bushing thou :lol: :lol:
Ed S. (IL)
05-03-2008 19:23:51
 Re: Operation 8N: Engine On! in reply to Ed S. (IL), 05-03-2008 18:48:33
Sean,
Your 9N is really coming along! My only excuse is that we've had nine house guests all week, and none of them are into wrenching on old tractors...
I still have a couple of hurdles to cross: stuck right radius arm pin and stuck axle kingpin, plus need to R&R the lift cylinder assembly before it goes back on. Everything else is pretty much clean, paint and install work.
Sent about $600 to the YT store yesterday, so hopefully UPS will be bringing goodies in a week or so...
es
Ed S. (IL)
05-03-2008 19:18:25
Paint is enamel red oxide primer from TSC. Got a gallon each of Ford Red and Grey all ready to lather on once everything else is primed.
es
John (TR)
05-03-2008 19:06:03
Looking good, what are you using for paint?
Colin King
05-03-2008 19:01:40
Ed, You've been making good headway. You'll be ready to go in time for the first hay cutting.
Colin
Sean (TX)
05-03-2008 19:01:00
 Re: Operation 8N: Engine On! in reply to Bruce in wny, 05-03-2008 18:48:33
You are falling behind Ed. Managed to BBQ left side brakes and put the axle back on.Going to get the right side axle back on sunday. Just need to clean brakes, pack bearings and replace the sure seal. Sure seal was not leaking on that side. Sill need to remove brake shaft and replace backing plate,
third party image
